Embed iframe panel without showing controls
hello
To share a panel ,embedded iframe, how can i insert this into a website and hide the controls such as the query,share etc?
I dont want to do a snapshot and I like the mouse over etc and I can pass from/end to the url.
Best Regards
Anthony
At the moment you can’t. We’re having plans on implementing backend plugin support and this could possibly support the requirements your asking for.
Marcus
You can append ‘&inactive=1’ to the Snapshot URL to hide panel controls.
Cheers
  • Is it implemented now?
I found out that there is a parameter called “&kiosk” (which is implemented) and hides the controls.
Together with Snapshots and &fullscreen in an iframe I’ve manged to show the data only. Very nice :wink:
