11.1.0 -
Trying to configure the Elasticsearch datasource to connect to a secured cluster (username/password authentication) -
What happened?
When clicking on “Save & Test” this message appears:
Unable to connect with Elasticsearch. Please check the server logs for more details.
When running a curl from the host where grafana is running on, all works just fine:
curl -XGET --user elastic:PASSWORD http://elasticsearch:9200/_cat/health?pretty
1729236641 07:30:41 cluster-name green 3 2 1700 854 0 0 0 0 - 100.0%
An OK. -
See above image -
When viewing the logs, it just says it got a 403 Forbidden. -
Configure the Elasticsearch data source | Grafana documentation
