Cloud elastic search aiuthentication
I am trying to connect to an elastic search deployment on https://www.elastic.co/ but hitting a wall with authentication maybe?
    8.4.5
    Connect to cloud elastic search
    Following the official ES doc
  • What happened?
    Bad Gateway
    Return results, just like it does to our internal elasticsearch
logger=data-proxy-log userId=1 orgId=1 uname=xxx path=/api/datasources/proxy/24/zebra/_mapping remote_addr=[::1] referer=https://community.grafana.com/datasources/edit/E4iN8elnk t=2022-05-12T15:02:50.38-0700 lvl=eror msg="Data proxy error" error="http: proxy error: net/http: invalid header field name \"apikey_key \""
logger=context t=2022-05-12T15:02:50.38-0700 lvl=eror msg="Request Completed" method=GET path=/api/datasources/proxy/24/zebra/_mapping status=502 remote_addr=[::1] time_ms=73 size=0 referer=https://community.grafana.com/datasources/edit/E4iN8elnk
    I am trying to follow this approach to get authentication to work
Using a free trial of es from https://www.elastic.co/
Thanks!
es = Elasticsearch(
    cloud_id=config['DEFAULT']['cloud_id'],
    api_key=(config['DEFAULT']['apikey_id'], config['DEFAULT']['apikey_key']),
This from the above document might lead to a solution
