What Grafana version and what operating system are you using? - 7.5.4
What are you trying to achieve? I’m trying to vizualize specific excerpts of the logs. I need to display performance of the specific entity on the graph.
How are you trying to achieve it? I added a new panel, and used ES6 cluster. I used the KQL to fetch the data.
What happened?
application: app1 AND severity: 3 AND labels: Partner157does not work
application: app1 AND severity: 3does work -
I expectapplication: app1 AND severity: 3 AND labels: Partner157query to work: i expect the data points to be on the graph. Instead nothing is shown -
Before I can share more I’d like to know if it’s a known limitation -
No errors. Good request and good response: 200 code. No data is returned in case of application: app1 AND severity: 3 AND labels: Partner157 . In case of application: app1 AND severity: 3 the correct data is returned.
All queries were triple checked before creating this post.
- Did you follow any online instructions? If so, what is the URL?
Lucene query not working as expected
How to effectively use the Elasticsearch data source in Grafana and solutions to common pitfalls | Grafana Labs
Thank you
