version-11.2.0 and deployed in kubernetes cluster -
i have dropdown variable created called cell which will have around 20k values and i am trying to create time series chart for displaying line trend of the kpi for each cell.So if user selects 3 cells in dropdown then 3 lines should be available in time series chart.
I got stuck with query,where query statement should dynamically create based on the cells selected in dropdown variable.Sample query pasted below,
SELECT
toDateTime(date_column) AS time,
SUM(CASE WHEN `cell name` ='cell1' THEN `kpi1` ELSE 0 END) AS `cell1`,
SUM(CASE WHEN `cell name` ='cell2' THEN `kpi1` ELSE 0 END) AS `cell2`
FROM
db_name.table_name
WHERE
PERIOD_START_TIME BETWEEN
toDateTime(1733077800000 / 1000) AND toDateTime(1733336999000 / 1000)
GROUP BY
time
ORDER BY
time;
I above query,below statement should dynamically created for each cells selected in dropdown…this is the place i got stuck,suppose if cell1,cell2,cell3 has been selected below statement should get generated thrice for cell1,cell2,cell3
SUM(CASE WHEN cell name =‘cell1’ THEN kpi1 ELSE 0 END) AS cell1,
- How are you trying to achieve it?
when i hardcode few cells then it is working fine but when i use (${cell}) in the query,value selected in the cell dropdown is getting substituted but not generating the full sum statement for each cell selected.Since looping is not available this is reaaly hard to achieve
What happened?
i tried with group,rows to field,organise by field name transformation…but not working -
pasted already -
seeking the support here
