Grafana v9.0.3 (023f9251a9) -
Adjust maxDataPoints based on the time range. Currently you can only set maxDataPoints to a fixed value or auto. This is not flexible since I need a maxDataPoints of 100 on high time ranges and 300 on shorter ones. Otherwise if set to auto then the value is much higher than desired and the dashboard fails to load -
I use fixed value MaxDataPoints -
What happened?
Very slow on long time ranges -
Should load faster -
"id": 6,
"gridPos": {
"h": 8,
"w": 24,
"x": 0,
"y": 9
"type": "timeseries",
"title": "Message Rate by Topic",
"datasource": {
"type": "elasticsearch"
"pluginVersion": "9.0.3",
"maxDataPoints": 200,
"description": "One Minute Rate",
"fieldConfig": {
"defaults": {
"custom": {
"drawStyle": "line",
"lineInterpolation": "linear",
"barAlignment": 0,
"lineWidth": 1,
"fillOpacity": 10,
"gradientMode": "none",
"spanNulls": false,
"showPoints": "never",
"pointSize": 5,
"stacking": {
"mode": "normal",
"group": "A"
"axisPlacement": "auto",
"axisLabel": "Messages Per Second",
"scaleDistribution": {
"type": "linear"
"hideFrom": {
"tooltip": false,
"viz": false,
"legend": false
"thresholdsStyle": {
"mode": "off"
"color": {
"mode": "palette-classic"
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"decimals": 0,
"min": 0,
"unit": "short"
"overrides": []
"options": {
"tooltip": {
"mode": "multi",
"sort": "none"
"legend": {
"displayMode": "hidden",
"placement": "right",
"calcs": []
"targets": [
"alias": "",
"bucketAggs": [
"field": "labels.topic",
"id": "2",
"settings": {
"min_doc_count": "1",
"order": "desc",
"orderBy": "1",
"size": "20"
"type": "terms"
"field": "@timestamp",
"id": "3",
"settings": {
"interval": "auto",
"trimEdges": "0"
"type": "date_histogram"
"hide": false,
"metrics": [
"field": "kafka.topic.MessagesInPerSec.OneMinuteRate",
"id": "1",
"settings": {},
"type": "sum"
"query": "environment:prod AND _exists_:kafka.topic.MessagesInPerSec.OneMinuteRate AND -labels.topic:_* AND labels.topic:$topic",
"queryType": "randomWalk",
"refId": "A",
"timeField": "@timestamp",
"datasource": {
"timeFrom": null,
"timeShift": null,
"transparent": true,
"interval": null
- name: Elastic
type: elasticsearch
access: proxy
url: host
database: "es-*"
withCredentials: false
isDefault: false
version: 1
editable: false
basicAuth: true
jsonData:
maxConcurrentShardRequests: 2048
tlsSkipVerify: true
timeField: "@timestamp"
timeout: 900
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
too_many_buckets_exceptionon longer time ranges. Which I need to lower for those ranges. - Did you follow any online instructions? If so, what is the URL?
N/A
