Is it possible to set up dual y axis with grafana cloud? All of the instructions I have found seem to be for running grafana on my own server.
Hi @lm9 - there are many topics that are applicable to both Grafana Cloud and a self-managed Grafana environment though it’s certainly easy to get lost in the docs! At the top of most documentation sources, there should be some handy labels to help clarify which Grafana environments are applicable.
For creating dual y axes, set the query results to a specific axis in the panel field override options. See the right-hand settings menu in the screenshot below:
You can take a closer look at the dashboard shown in the screenshot above on our demo page:
And the docs for working with panel options and field overrides can be found here:
That is perfect. Thank you very much.
