Greetings
Is it possible to do dual axis for bar chart to show some trendline? I have configured two overrides but does not show the second axis.
Sample data
metric,value,trend
A,1,2.5
B,3,2.5
C,2,2.5
D,4,2.5
E,3,2.5
Thanks
Hi!
Were you able to solve this ?
I find myself trying to do the same ,
Thanks in advance
hello,
You can check this post maybe,
had kind of same issue, i would display forecast on top of other line.
i could get it through time series panel.
Hey @yosiasz
Also, this plugin can also help you out.
