Does RBAC requires License?
Grafana version: Version 9.5.3 (commit: 916d9793aa, branch: HEAD) - open source
OS & version: Red Hat Enterprise Linux release 8.8 (Ootpa)
Trying to implement RBAC
    enabled RBAC in grafana.ini
    [rbac]
    enabled: true
    permission_cache: true
Using file provisioning method - /etc/grafana/provisioning/access-control
config file version
apiVersion: 2
Roles to insert/update in the database
roles:
  • name: ‘custom:users:goc’
    description: ‘List/update other users in the organization’
    version: 1
    global: true
    permissions:
    • action: ‘dashboards:read’
      scope: ‘dashboards:’ 'folders:’
    • action: ‘alert.instances.external:read’
      scope: ‘datasources:*’
    • action: ‘alert.instances:create’
    • action: ‘alert.instances:write’
    • action: ‘alert.instances:read’
Assignments to teams
teams:
  • name: ‘GOC’
    orgId: 1
    roles:
    Custom role assignment
      global: true
  • What happened?
no custom role visible in UI
