POST /api/admin/provisioning/access-control/reload returns "Not found" in Grafana
I want to create a grafana user without using Admin credentials. I was trying to create a user using API in grafana using the code below:
curl -XPOST -H "Content-Type: application/json" -d '{
  "name":"User",
  "email":"user@graf.com",
  "login":"user",
  "password":"userpassword"
}' https://user:password@<host>/api/admin/users
After this, I got an error which made me think I do not have sufficient permissions as a grafana user to do this and could create the user using Grafana Admin credentials.
"accessErrorId":"ACE7538001967",
"message":"You'll need additional permissions to perform this action. Permissions needed: users:create",
"title":"Access denied"
So, I tried implementing RBAC. The way I did this is to:
Edited etc/grafana/provisioning/access-control/sample.yaml file with contents:
# # config file version
 apiVersion: 2
 # <list> list of roles to insert/update/delete
 roles:
   # <string, required> name of the role you want to create or update. Required.
   - name: 'custom:users:writer'
     # <string> uid of the role. Has to be unique for all orgs.
     uid: customuserswriter1
     # <string> description of the role, informative purpose only.
     description: 'Create, read, write users'
     # <int> version of the role, Grafana will update the role when increased.
     version: 2
     # <int> org id. Defaults to Grafana's default if not specified.
     orgId: 1
     # <list> list of the permissions granted by this role.
     permissions:
       # <string, required> action allowed.
       - action: 'users:read'
         #<string> scope it applies to.
         scope: 'global.users:*'
       - action: 'users:write'
       - action: 'users:create'
And then according to this doc: Provisioning RBAC with Grafana | Grafana documentation
I hit the API using curl as an Admin user to reload provisioning configurations:
curl -X POST https://admin:admin@<host>/api/admin/provisioning/access-control/reload -H "Accept: application/json" -H "Content-Type: application/json"
But I got this response:
{“message”:“Not found”}
Other API calls work for example,
curl -X POST https://<admin>:<admin-pwd>@<my-host>/api/admin/provisioning/notifications/reload
{"message":"Notifications config reloaded"}
What should I have done differently? Any help would be appreciated.
Grafana docs are definitely not that straightforward.
Thanks a lot, in advance!
I was expecting this API response to be something like 200 OK.
curl -X POST https://<admin>:<admin-pwd>@<my-host>/api/admin/provisioning/access-control/reload
Can anyone please help me out here?
Are you using the Grafana OSS free version or the Enterprise one with a license?
Hi @usman.ahmad thanks for your reply. We are using the OSS version.
@jangaraj can you please assist in this one ? :slight_smile:
I guess you don’t have Grafana version, which support it.
I’m using Grafana version: 9.5.2
So did you check documentation, release notes for your version?
Yes.
See linked doc:
Note: Available in Grafana Enterprise and Grafana Cloud Advanced.
But you have Grafana OSS. So I would say again, that 404 (Not Found) response is correct. You are trying to use feature, which is not available in your Grafana version.
Hello, I’m trying to make dynamic panels in Grafana from CSV files but I can’t link variables to the panel. Do you know if with CSV files you can’t use variables?
