I have followed the below steps -
Got the grafana code v5.4.3
Set GOPATH
Installed the backend using -
go run build.go setup
go run build.go build
Followed below steps to build the frontend -
npm install
npm install -g grunt-cli
grunt
I was able to get grafana running at http://grafana.staged-by-discourse.com.
Then I introduced my dashboard files and plugin files.
After running grafana at http://grafana.staged-by-discourse.com, I saw that the plugin js files are not minified in the browser. They are loading one by one.
Then I did grunt build and grunt release for a minified build.
grunt release created a zip file under dist folder.
When I unzip the file, I see that it does not contain bin folder.
How do I use this zip file to serve minified files while running grafana?
