It used to be that just running “grunt” would generate unminified versions the the scripts that Grafana runs on (and then a browser’s dev tools could be used to step through those scripts). But since the last build changes to webpack, I am unsure of what the replacement is. How to run a version of Grafana that serves unminified scripts.
I also feel that the “Building from source” documentation has never made it particularly clear either.
Thanks for any guidance!
