Hi, there,
I am wondering if it’s possible to PUT explore queries to grafana so that you can later click on them and observe the results.
For example I programmatically (i.e. via Lambda) describe 5 different CloudWatch metrics so I know the time frame I want, the dimensions, etc.
Can I then PUT a request to grafana’s API so that when I then login to grafana I can go to the query history and found what I have PUT, click it and observe the outcome.
I know I can put JSON to create a dashboard but I want something less permanent.
I would rather have a button in a dashboard that triggers the Lambda that PUTs the explore query to be used.
I hope I can achieve some “view corresponding metrics” functionality that way. (The logic to determine what is corresponding is outside grafana of course (the lambda)) but I need to obtain timeframe and metric from a dashboard, pass it to something external (i.e. via button with JS if possible), and then put the result to be examined in Explore.
I can’t seem to find explore related stuff in the HTTP API documentation.
Any ideas?
