We’re deploying Grafana within Docker and I want to make sure I’m packaging everything that’s needed. The last bit of our dockerfile is:
# Basic dependencies for building Grafana NPM project
RUN \
npm install -g yarn && \
yarn config set "strict-ssl" false && \
yarn install --pure-lockfile && \
npm run build
# Building of Grafana backend
RUN \
go run build.go setup && \
go run build.go build
# Create final stage containing only required artifacts
FROM scratch
COPY --from=build /bin/grafana-server /bin/grafana-server
EXPOSE 3001
CMD ["./bin/grafana-server"]
My question is will the final artifact of grafana-server
contain the changes that were built as part of npm run build
? If so, how? I’d like to understand these correlations better (if they exist).
Thanks!
