Docker /tmp permission problem
    dietpi 7.5.2 debian bullseeye
    docker container grafana latest
    start docker container successfully
    docker-compose
  • What happened?
    container doesn’t start
    container run
grafana:
image: grafana/grafana:latest
container_name: grafana
restart: always
user: “1000”
network_mode: host
volumes:
- ./grafana/data:/var/lib/grafana # data path
  • ./grafana/provisioning:/etc/grafana/provisioning
    • ./configfiles/custom.ini:/etc/grafana/grafana.ini
      environment:
  • GF_INSTALL_PLUGINS=grafana-clock-panel,grafana-simple-json-datasource
  • GF_SECURITY_ADMIN_USER=${GF_SECURITY_ADMIN_USER}
  • GF_SECURITY_ADMIN_PASSWORD=${GF_SECURITY_ADMIN_PASSWORD}
Error: ✗ Get “https://grafana.com/api/plugins/repo/grafana-clock-panel”: dial tcp: lookup grafana.com on 127.0.0.1:53: read udp 127.0.0.1:55701->127.0.0.1:53: read: connection refused
Error: ✗ failed to create temporary file: open /tmp/376482387.zip: permission denied
Error: ✗ failed to create temporary file: open /tmp/112431570.zip: permission denied
Error: ✗ failed to create temporary file: open /tmp/506707309.zip: permission denied
Error: ✗ failed to create temporary file: open /tmp/746178320.zip: permission denied
I use grafana as part of my home assistant docker install. Yesterday I have upgraded debian buster to debian bullseye. Exact the same config has worked fine before.
The data files are stored as user 1000 (dietpi) and the user can create files in tmp.
dietpi in DietPi in ~ ✦ ❯ id
uid=1000(dietpi) gid=1000(dietpi) Gruppen=1000(dietpi),4(adm),5(tty),20(dialout),24(cdrom),27(sudo),29(audio),33(www-data),44(video),46(plugdev),60(games),100(users),101(input),108(netdev),121(render),997(gpio),998(i2c),999(spi)
dietpi in DietPi in ~ ✦ ❯ touch /tmp/4947
I just don’t understand were the error comes from. What is meant, the /tpm of the host or /tmp inside the container?
Can someone point me to the right direction.
TIA Micha
The problem is that inside the container not a writable tmp dir is.
Now I have set
  • TMPDIR=/var/lib/grafana/tmp
    in docker compose file. Now it works
