I’ve got the following compose:
version: '3'
services:
grafana:
image: grafana/grafana:latest
ports:
- '37000:3000'
volumes:
- grafana-storage:/grafana-storage
- grafana-data:/grafana-data
- grafana-provisioning:/grafana-provisioning
environment:
- GF_SECURITY_ADMIN_USER=${GRAFANA_USERNAME}
- GF_SECURITY_ADMIN_PASSWORD=${GRAFANA_PASSWORD}
- GF_PATHS_STORAGE="/grafana-provisioning"
# - GF_PATHS_DATA="/grafana-data"
# - GF_PATHS_CONFIG="/grafana-storage/grafana.ini"
deploy:
placement:
constraints:
- node.role==worker
volumes:
grafana-data:
driver: local
driver_opts:
device: :/DockerDisks/grafana/storage/data
o: addr=${NAS_HOST},rw,vers=4
type: nfs
grafana-storage:
driver: local
driver_opts:
type: nfs
driver: local
driver_opts:
device: :/DockerDisks/grafana/provisioning
type: nfs
If I enable GF_PATHS_DATA or GF_PATHS_CONFIG line, I’m greeted with permission denied errors and failure to deploy.
Within the container itself, with those lines commented out.
ls -lah / shows
drwxr-xr-x 1 root root 4.0K Oct 15 19:10 .
drwxr-xr-x 1 root root 4.0K Oct 15 19:10 ..
-rwxr-xr-x 1 root root 0 Oct 15 19:10 .dockerenv
drwxr-xr-x 1 root root 4.0K Oct 8 10:20 bin
drwxr-xr-x 5 root root 340 Oct 15 19:10 dev
drwxr-xr-x 1 root root 4.0K Oct 15 19:10 etc
drwxrwxrwx 2 grafana grafana 4.0K Oct 15 18:39 grafana-data
drwxrwxrwx 6 grafana grafana 4.0K Oct 13 17:56 grafana-provisioning
drwxrwxrwx 3 grafana grafana 4.0K Oct 15 18:37 grafana-storage
drwxr-xr-x 1 root root 4.0K Oct 8 10:20 home
drwxr-xr-x 1 root root 4.0K Oct 8 10:20 lib
drwxr-xr-x 5 root root 4.0K May 29 14:21 media
drwxr-xr-x 2 root root 4.0K May 29 14:21 mnt
drwxr-xr-x 2 root root 4.0K May 29 14:21 opt
dr-xr-xr-x 208 root root 0 Oct 15 19:10 proc
drwx------ 2 root root 4.0K May 29 14:21 root
drwxr-xr-x 1 root root 4.0K Oct 8 10:20 run
-rwxr-xr-x 1 root root 3.3K Oct 8 10:19 run.sh
drwxr-xr-x 2 root root 4.0K May 29 14:21 sbin
drwxr-xr-x 2 root root 4.0K May 29 14:21 srv
dr-xr-xr-x 12 root root 0 Oct 15 19:10 sys
drwxrwxrwt 2 root root 4.0K May 29 14:21 tmp
drwxr-xr-x 1 root root 4.0K Oct 8 10:20 usr
drwxr-xr-x 1 root root 4.0K Oct 8 10:20 var
from the NFS host, the relevant folder shows
drwxrwxrwx 4 472 472 4.0K Oct 1 13:55 grafana
All that says to me is that the permissions line up between NFS server, and container. Plus, the 777 permissions should let anything read/write into the NFS store.
What’s going on here that I’m missing?
