What happened:
Grafana CloudWatch datasource unable to find a credentials provider.
I see the following error in the docker container logs when I test the CloudWatch datasource.
“Failed to get regions” logger=tsdb.cloudwatch error=“NoCredentialProviders: no valid providers in chain. Deprecated.\n\tFor verbose messaging see aws.Config.CredentialsChainVerboseErrors”
What you expected to happen:
Grafana CloudWatch datasource running in docker should read the volume mounted credentials file in ~/.aws. I also tried /usr/share/grafana/.aws
How to reproduce it (as minimally and precisely as possible):
Dockerfile
FROM grafana/grafana:6.4.0
WORKDIR /etc/grafana
COPY conf .
COPY datasources provisioning/datasources/
ENV GF_AUTH_DISABLE_LOGIN_FORM "true"
ENV GF_AUTH_ANONYMOUS_ENABLED "true"
ENV GF_AUTH_ANONYMOUS_ORG_ROLE "Admin"
ENV AWS_SDK_LOAD_CONFIG "true"
datasources/aws-cloudwatch.yaml
apiVersion: 1
datasources:
- name: cloudwatch-data-prod
isDefault: true
type: cloudwatch
database: xilution-prod
jsonData:
authType: credentials
defaultRegion: us-east-1
conf/custom.ini
# default section
instance_name = xilution-grafana
To Build Image
docker build -t xilution/xilution-grafana .
To Run
docker run --name xilution-grafana -d -p 3000:3000 -v $(HOME)/.aws/:/home/grafana/.aws xilution/xilution-grafana
To See Logs
docker logs -f xilution-grafana
Anything else we need to know?:
Environment:
- Grafana version: 6.4.0
- Data source type & version: CloudWatch
- OS Grafana is installed on: Docker
- User OS & Browser: Mac OS/Chrome
- Grafana plugins: None
- Others: I use credentials and a config files for AWS authentication.
