Docker Build failed make: *** [build-docker-full] Error 1
I’m trying to build docker image from latest source code ( #52420) currently)
and I got following error, Is that mean I need to install some go modules or sth ?
failed to compute cache key: "/cue" not found: not found
full log :
make build-docker-full
build docker container
docker build --tag grafana/grafana:dev .
[+] Building 2.4s (25/49)
 => [internal] load build definition from Dockerfile        0.0s
 => => transferring dockerfile: 37B        0.0s
 => [internal] load .dockerignore        0.0s
 => => transferring context: 35B        0.0s
 => [internal] load metadata for docker.io/library/alpine:3.15        1.7s
 => [internal] load metadata for docker.io/library/node:16-alpine3.15        1.8s
 => [internal] load metadata for docker.io/library/golang:1.17.12-alpine3.15        1.8s
 => [auth] library/alpine:pull token for registry-1.docker.io        0.0s
 => [auth] library/golang:pull token for registry-1.docker.io        0.0s
 => [auth] library/node:pull token for registry-1.docker.io        0.0s
 => [internal] load build context        0.5s
 => => transferring context: 1.08MB        0.5s
 => CANCELED [go-builder  1/14] FROM docker.io/library/golang:1.17.12-alpine3.15@sha256:50d232dc45a3e846d36b20f3312cc7b893354b9451038108826d988b92dcfd4d        0.5s
 => => resolve docker.io/library/golang:1.17.12-alpine3.15@sha256:50d232dc45a3e846d36b20f3312cc7b893354b9451038108826d988b92dcfd4d        0.0s
 => => sha256:e530ab5b7323d6d3be5ad921da98e981180263d95d9fc0d3adc109891462250f 1.36kB / 1.36kB        0.0s
 => => sha256:28715183cf3046915785a04ef0232b032bec02363fb5aa67f4ff9b12a5487019 5.25kB / 5.25kB        0.0s
 => => sha256:bf1a8f2ddd1b017a1aa5ebc3de14f30c9e178fd6a6410facbd269d4051a3b2de 271.76kB / 271.76kB        0.3s
 => => sha256:8a6f4eac29ba61aa682d02d699902c484230d49bf27180380c1738e2d1484f8a 0B / 155B        0.5s
 => => sha256:67b6d5075bc797830bc5edb12978712b3530cc97ed484ea60c2e0d53eae12eee 0B / 104.14MB        0.5s
 => => sha256:50d232dc45a3e846d36b20f3312cc7b893354b9451038108826d988b92dcfd4d 1.65kB / 1.65kB        0.0s
 => => extracting sha256:bf1a8f2ddd1b017a1aa5ebc3de14f30c9e178fd6a6410facbd269d4051a3b2de        0.1s
 => => sha256:386291b2bcca97c34670c6cad52d968d28d70262d66e0aadcafad3a4b385616b 0B / 125B        0.5s
 => [stage-2  1/13] FROM docker.io/library/alpine:3.15@sha256:0483110c51a764abe175a8cefb941541ca0bc0f628ce418d3a660338abf4622a        0.0s
 => [js-builder  1/13] FROM docker.io/library/node:16-alpine3.15@sha256:3cc4a16286bc01e141dcfec735f3ebfaf8bdb6ab7ff216f9a7073bd08cee1fa7        0.0s
 => CACHED [stage-2  2/13] WORKDIR /usr/share/grafana        0.0s
 => CACHED [stage-2  3/13] RUN apk add --no-cache ca-certificates bash tzdata musl-utils        0.0s
 => CACHED [stage-2  4/13] RUN apk add --no-cache openssl ncurses-libs ncurses-terminfo-base --repository=http://dl-cdn.alpinelinux.org/alpine/edge/main        0.0s
 => CACHED [stage-2  5/13] RUN apk upgrade ncurses-libs ncurses-terminfo-base --repository=http://dl-cdn.alpinelinux.org/alpine/edge/main        0.0s
 => CACHED [stage-2  6/13] RUN apk info -vv | sort        0.0s
 => CACHED [go-builder  2/14] RUN apk add --no-cache gcc g++ make        0.0s
 => CACHED [go-builder  3/14] WORKDIR /grafana        0.0s
 => CACHED [go-builder  4/14] COPY go.mod go.sum embed.go Makefile build.go package.json ./        0.0s
 => ERROR [go-builder  5/14] COPY cue cue        0.0s
 => CANCELED [stage-2  7/13] COPY conf ./conf        0.0s
 => CACHED [js-builder  2/13] WORKDIR /grafana        0.0s
 => CACHED [js-builder  3/13] COPY package.json yarn.lock .yarnrc.yml ./        0.0s
 => CANCELED [js-builder  4/13] COPY .yarn .yarn        0.0s
 > [go-builder  5/14] COPY cue cue:
welcome to the :grafana: forum, @fallenzone
is there a special reason that you need to package your own docker image of Grafana?
Hi @mattabrams,
I want to add language package in my grafana project.
I see. So good news is the Grafana frontend teams are working on a large internationalization program. Can I ask: what language support did you want?
Hi @anon70503803 ,
that is really great news about grafana teams working on it :smiley:
but I’m still interesting how can I solve this build failed problem.
