Django login to grafana
Hi all,
I am very new to using grafana and need some advise with the following.
I have a django application that gets data from postgres db.
I want the data to be sent in json to grafana.( this works)
I want to bypass the grafana login and want to use the django login credentials to see the data that is linked to the logged in user.
If for example a different user logs in they would use the same grafana dashboard but with the data that is linked to them.
I hope i was clear enough for someone to assist
