Hi you all guys,
I have nginx in front o Django with WSGI.
I authenticate a user with Django and I would like the same user, who exists on Grafana, is already logged in his own default dashboard.
I fell that valid options are 2:
- use the auth.proxy and set the X-WEBAUTH, but to prevent header spoofing NGINX should set it (or remove it) only if it found a valid (or an invalid) session cookie for Django
- create Grafana session table in PostgreSQL db, and let Django and Grafana session tables synchronize
Option 1: NGINX sets X-WEBAUTH
I have no clue on how to do it, maybe using some conditions on one of the vars in http://nginx.org/en/docs/varindex.html ?
Options 2: Synchronize Session tables
I have created my session table, I can fill it with the same hex key of the sessionid cookie used in Django, I can set the “expiry” field with unix epoch timestamp BUT I have no idea on what it goes in the “data” field.
I have searched in the Grafana source code in the Github repo, in the go-macaron framework (is Grafana based on it?), it seems to be a gob encoded struct, but I have no experience in go and I have not found a program to read the content and maybe create the same data with python/Django or a TRIGGER in the database.
I have seen that if I provide a valid key in the session cookie and in the table the data field is NULL, it is populated, but still the login form happens.
I have seen that there is a “remember” cookie that seems to affect the behaviour, and in the source code it is referred as SuperSecureCookie so damn … it does its work very well if so!
Example of row with valid session data
-[ RECORD 6 ]--------------------------------------------------------------------------------------
key | 259cbf49202cdf5f
data | \x0eff81040102ff82000110011000001cff82000106737472696e670c05000375696405696e74363404020002
expiry | 1505547260
Example of row with session data created by Grafana when session data is NULL
sessionid cookie “forged” (you can think “passed by Django”)
-[ RECORD 1 ]--------------------------------------------------------------------------------------
key | 3212aabbcc
data | \x0eff81040102ff820001100110000004ff820000
expiry | 1505548885
Last note and conclusions
Django is a framework that can be versatile on SessionStorage, so I can change it, but I do not think it will address the issue
Conclusions: I am stuck with this User Story. In my job career I have integrated a bunch of different web applications, but it seems that with Grafana I am taking the wrong path.
Thank you in advance
fero
