my goal is to create graph which shows min, max and current number of calls over time. I have tried to do it by myself however with not much luck.
I’m using NXlog to parse my raw logs to Graylog where they are being aggregated(grok patterns) and finally showed in Grafana also i have installed a reporter plugin to be able to save the dashboard in pdf file. It’s possible to get simple queries like count of specific field or calculate successful rate of my application. My configuration:
I think it’s strange that i can’t set the fields which should be in found document.
however in group by they are there
Is my approach wrong? If yes how can i do it in the different way?
PS. There is a function to show avg, sum, min, max and so on as a table maybe somebody know if it is possible to take those points and use them as graph data. I’m more than happy to give more information if needed!
Graylog 3.0.1
Elasticsearch 6.6.2
Grafana 6.1
