Displaying data in bar chart from many tables
    v12.2
    I’d like to see a dashboard which shows the time in minutes since last data record in every separated table. (Table name / minute)
    I created a variable selecting table names:
    SELECT table_name
    FROM information_schema.tables
    WHERE table_schema = ‘emspressigstrom’
    AND table_name REGEXP ‘[1]{3}’;
    multi value is off
    And a query in a bar chart:
    SELECT
    ‘${table}’ AS table_name,
    TIMESTAMPDIFF(MINUTE, MAX(Zeit), NOW()) AS delay_minutes
    FROM ${table};
    The Repeate option is selected, “table” is selected
  • What happened?
    The repeating of bar chart for each table doesn’t work, only selected table can be seen.
    A expected to see repated chart for each table
Error message if “Include All option” is selected in Variable
db query error: Error 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ‘’’ AS table_name, TIMESTAMPDIFF(MINUTE, MAX(Zeit), NOW()) AS delay_minutes…’ at line 2
  1. 0-9 ↩︎
What do you get when you run
SELECT table_name
AND table_name REGEXP ‘{3}’
Outside of grafana in a SQL tool for Mariadb, examine the list of tables being returned. Are they all valid table names
Here is the solution:
All option is needed in the Variable and it has to be selected on the dashboard
Repeat option: table (Variable name has to be selected)
Query: FROM ${table:raw} form is required
