Display UP down instead of 1 or 0
Since the update of Grafana 7v → 8v I don’t have the “UP” or “DOWN” display anymore.
Before the Grafana update I was monitoring the ports of my switch and the ping of some of my servers when it was online my grafana displayed UP or DOWN now I have an error… that since the update… Now if I want a value, I can only have 1 for UP and 0 for down (see capture)
Do you have a solution?
I use since the beginning the Zabbix plugin to remount my equipment on Grafana.
(On the second picture you can see what it shows me since the upgrade of Grafana).
Were (or are) you using value mappings, like this?
without value mappings:
with value mappings:
Thank you very much! I was able to put what I wanted!
