What Grafana version and what operating system are you using?*
Grafana Playground
Grafana v11.1.0-69950 -
I need to display the result of dividing TimeSeries-value from Datasource 1 by plain-SQL-query value from Datasource 2 within a single dashboard -
I retrieve data from 2 different Datasources within a single dashboard (I use --Mixed-- datasource); first datasource sends data in TimeSeries format (result 1), second datasource - as a plain SQL query response (result 2).
I create “Expression” Element in Query tab:
Type: Expression
operation: Math
Expression: $DataSourceA / $DataSourceB
What happened?
“No data” text is displayed in a new column; Warn-Icon with Status 500, Status text: “Internal server error”, url: “api/ds/query?expression=true” -
A new column with the result of dividing TimeSeries-value from Datasource 1 by plain-SQL-query value from Datasource 2 -
Did you receive any errors in the Grafana UI or in related logs?
Warn-Icon with Status 500 in a new column, Status text: “Internal server error”, url: “api/ds/query?expression=true”
