Display popup on Dashboard Panel either by with or without moving mouse curser
I have a requirement on showing the popup on dashboard panel when moved the mouse or tab on to the panel. this popup contains specific text details contents ,is there any plugin or any approach that it can be achieved ?
Thanks,
Ravi
Hi @ravivishpln Which popup are you referring to? Can you provide a screenshot?
you could try a data link, set what you want to popup as the link title, and set the url to #
You can try to turn on tooltip so you can view the popup on dashboard panel
Here’s all the steps:
  1. Go to your panel settings
  2. On the panel options go to tooltip option and select the always option
By following these steps you can see the display popup including information text details etc.
