eggy
May 14, 2024, 12:42pm
1
Let’s say I have this query in loki
{tenant_id="tenantId"}
|= `ERROR`
| label_format date=`{{ __timestamp__ | date "2006-01-02"}}`
| pattern `<_> name=<name> `
| label_format name=`{{ .name }}`
I want to have the data presented in a Table. When I Transform the data, I can do a Group By (date ) and I can go to Calculate → All Values and then I can see all Values i.e.
[ "2024-05-14", "2024-05-14", "2024-05-14", "2024-05-13"]
Now I want to have a count, where if the same value occurs 3 times, increment it by one. so for the example above, the count will 1 one
For the example below the count will be 2
[ "2024-05-14", "2024-05-14", "2024-05-14", "2024-05-13", "2024-05-12", "2024-05-12", "2024-05-12"]
I am struggling to achieve this, can someone please help me
Hi eggy,
what ever you do with loki,
after that you have to transform the data.
first - “Extract fields” by labels
then - “Filter fields by name”
then - “Convert the field type” because from loki you get only text
then you can give us an exacly example whats in the table view.
Jo
eggy
May 15, 2024, 12:43pm
3
group by
So for instance, I’d like another column (let’s say called fail count), that contains the logic "if a date (string, even) is repeated 3 times, increment the count by 1)
so
["2024-05-15","2024-05-15","2024-05-15"]
would produce 1.
but
["2024-05-15"]
would produce 0 .
however
["2024-05-15","2024-05-15","2024-05-15", "2024-05-14","2024-05-14","2024-05-14"]
would produce 2 and so on
It confuses me a little bit that it is always the same date.
How am I supposed to assign a count?
I am searching for the key…
eggy
May 15, 2024, 2:43pm
5
This is the raw query
{tenant_id="tenantId", cluster_name="clusterName"}
|= `ERROR`
date is a label_format
check this out here for some grouping syntax
try to do your aggregation in the data source and leave the visualization to grafana is my motto
eggy
May 15, 2024, 5:26pm
7
If i aggregate the data with Loki as such
count by (date, websiteId) (
count_over_time(
|= `ERROR`
[$__range]
) > 2
I am unable to see the data in Transform when I try to extract the values
well you might not have any data > 2
what do you see when you do
count_over_time(
|= `ERROR`
[$__range]
show us the data view
eggy
May 15, 2024, 7:18pm
9
There are matches but the ‘label {}’ are not coming up in the ‘source’ when i extract fields.
If i exclude the ‘count by’ and the ‘count_over_time’ I am able to see the ‘label {}’ in the Source
eggy
May 16, 2024, 8:16am
10
Ok i managed to do it.
I was displaying the values as part of a range Type instead of an instant .
I also added all the values I wanted to see in the table to the count by (date, websiteId) so I could see it in the table.
With regards to the count I done a transformation, in the group by i set the failures Calculate as Count.
Thanks all
