Discord notification Grafana 9 not working
I was able to setup discord channel but I think maybe somehow I miss something in the configuration of sending alert notification in discord channel. The contact points for discord is working fine, I have tested it and I got notification by test bot but I want to get the alert notification when it is alerting.
Welcome
What do you in this tab?
and your alerts have the labels key value= term:operations?
This is my label setting for this alert
what happens if you open your discord contact point and run test?
I get test notification in my discord channel
and what do you see here
Also please post grafana log section that might deal with alerts?
where is grafana logs?
I don’t know how to check logs from grafana dashboard. can you tell me how to get this?
please check here ^
