Direct link rendered image
As the cli command shows you installed the plugin not a render server. You don’t have a render server hence nothing on 8081.
Use something like following by adding /render/ on any dashboard
localhost:3000/render/d/748hrhjdirj
example before render added in url path
example after render added in url path
I can do something like β€œhttp://localhost:3000/d/pc5AnppIz/” that I can copy form Panel β†’ Settings β†’ Share panel β†’ Link URL, but I need automated rendering for reporting purposes (ruby-grafana-reporter). For that purpose I will need to activate Direct link rendered image. But I am stuck.
Any other reporting suggestion for OSS Grafana is welcome.
first off did using the suggested approach of adding /render/ to the dashabord url work?
No. If I add render I got some small icon.
did you clear out the settings you added to your .ini file that are supposed to be for render server which you do not have
server_url =
callback_url =
and restarted grafana?
It does not work. I cleared
server_url =
callback_url =
Tried with comment
;server_url =
;callback_url =
Tried with http://localhost:3000/render/d/pc5AnppIz/Dasboard_name?orgId=1&refresh=30s&from=1737654591117&to=1737665391117&viewPanel=2
But got result:
After that Render pluggin disable and has to be reinstalled.
Not sure I understand last post
Did you restart grafana?
I cleared
server_url =
callback_url =
Restarted Grafana
Tried with comment
;server_url =
;callback_url =
Restarted Grafana
But got result:
Each time after I do the same procedure Image render pluggin is disabled.
For testing, Install a separate grafana instance same version, install render plugin, create a simple dashboard, then try /render/ on that dashboard
No luck. Same problem. I have Grafana 10, could that be a problem?
Try latest version on the test instance
Just one question not connected to the present topic - what Grafana version support XY Chart?
