Hi all,
I just tried to get Direct link rendered image,but it can not display Chinese,only English.How can I to fix the problem.
Is it possible to install Chinese fonts on the operating system Centos?
I tried to change system language in /etc/locale.conf.
LANG=“zh_CN.UTF-8” SYSFONT=“latarcyrheb-sun16” SUPPORTED=“zh_CN.UTF-8:zh_CN:zh”
And I reboot the server.
But it doesn`t work.
you can do like this link(https://www.cnblogs.com/taoge188/p/8609630.html),try to install SONGTI.Don’t need reboot------
I tried to work -----------------
