i have got this message when i set prometheus server url
Post “http://127.0.0.1:9090/api/v1/query”: dial tcp 127.0.0.1:9090: connect: connection refused - There was an error returned querying the Prometheus API.
please help me to solve this.
type ifconfig on your system to get the local ip address and use that instead of localhost
This seems to be a configuration issue. Please check if you need to enable firewall OR use localhost instead of IP address (maybe best is to update your /etc/hosts file)
thanks this work for me
I checked my ipconfig after i paste it here like this one :
job_name: “nodejs_app”
scrape_interval: 3s
static_configs:
targets: [“192.168.29.103:3000”]
labels:
app: “nodejs”
hello @amandhn5973 welcome to grafana community thanks for the updated.
