Grafana 8.0.6 / windows-10 -
Center and scale diagram to panel size & center text vertically. -
Diagram: can’t find center or scale to panel options in panel.
Text: text ABC, centers text horizontally only. -
What happened?
@grafanauser10 can you please link to the exact plugin that you are using to create these diagrams?
Hi @anon70503803,
I’m using Diagram Panel “grafana-cli plugins install jdbranham-diagram-panel” v 1.7.3
