Deleted alerts still alerting and visible from alert groups
Hi!
There has been some housekeeping of alerts which were originally created via the legacy alert (now running unified alerting) and I have noticed they are still alerting even though the alert rules no longer exist.
When I go to alert groups, I can see them in an active state but when I select “see source” I get the message back “Rule could not be found”.
How do I fully delete the alerts?
Hello!
I have the same problem. I have annoying alerts which are not connected to any rule. I can’t find a way to delete those alerts.
When I press “See source”, rule could not be find:
Is there a way to delete those alerts?
Thank You!
Ended up sending a DELETE to /api/v1/provisioning/alert-rules/rule_UID to remove them
Thank you for the hint. Is this command still valid?
In my case:
GET domain.com:3000/api/alerts/?id=650 … lists multiple items
GET domain.com:3000/api/alerts/650 … lists single item
but
DELETE domain.com:3000/api/alerts/650
shows
“message”: “Not found”
/api/alerts is for the legacy platform, grafana allows you to rollback to legacy hence config still exists but not utilised (see Alerting HTTP API | Grafana documentation)
You want to be going via /api/v1/provisioning/alert-rules, if you are on 9.4 you can list all the alert rules by hitting /api/v1/provisioning/alert-rules directly.
