Windows Server 2019 v. 1809 build 17763.6054
Grafana v11.1.3 (beac3bdbcb) -
I’m trying to delete File Provisioned Alerts, basically I created a rule group manually, exported it, programatically changed the query information (queries to InfluxDB, same queries, different bucket) and uids, put that json on the conf/provisioning/alerting and now, the original rule group created manually was expanded, and I want to delete the provisioned one or disable provenance to either modify it manually or delete it altogether and establish a more “automated” provisioning flow -
I created a node.js script that fetches all the Alert Rules under a FOLDER and RULE-GROUP using:
I fetched and identified the uids of folders that I need and the rule group is “10s”
for (const folderUid of folderUids) {
const request = await grafanaApi.get(`/folders/${folderUid}`);
console.log(request.data);
then I tried to send an empty PUT request like the documentation says here:
const response = await grafanaApiProvisioning.put(
`/folder/${folderUid}/rule-groups/${group}`,
{} // Sending empty data as specified
I also tried deleting the group:
try {
const response = await grafanaApiProvisioning.delete(
console.log(`Successfully delete folder and rule group!`);
} catch (error) {
console.error(JSON.stringify(error, null, 2));
- What happened?
For the updating FOLDER and RULE GROUP case:
PS C:\projects\alerts.replaced.for.privacy.com> node .\alertUpdateWithEmpty.js
"message": "Request failed with status code 400",
"name": "AxiosError",
"stack": "AxiosError: Request failed with status code 400\n at settle (file:///C:/projects/alerts.replaced.for.privacy.com/node_modules/axios/lib/core/settle.js:19:12)\n
at IncomingMessage.handleStreamEnd (file:///C:/projects/alerts.replaced.for.privacy.com/node_modules/axios/lib/adapters/http.js:599:11)\n at IncomingMessage.emit (node:e
vents:531:35)\n at endReadableNT (node:internal/streams/readable:1696:12)\n at process.processTicksAndRejections (node:internal/process/task_queues:82:21)\n
at Axios.request (file:///C:/projects/alerts.replaced.for.privacy.com/node_modules/axios/lib/core/Axios.js:45:41)\n at process.processTicksAndRejections (node:internal/proc
ess/task_queues:95:5)\n at async sendEmptyDataPutRequest (file:///C:/projects/alerts.replaced.for.privacy.com/alertUpdateWithEmpty.js:32:26)",
"config": {
"transitional": {
"silentJSONParsing": true,
"forcedJSONParsing": true,
"clarifyTimeoutError": false
"adapter": [
"xhr",
"http",
"fetch"
"transformRequest": [
null
"transformResponse": [
null
"timeout": 0,
"xsrfCookieName": "XSRF-TOKEN",
"xsrfHeaderName": "X-XSRF-TOKEN",
"maxContentLength": -1,
"maxBodyLength": -1,
"env": {},
"headers": {
"Accept": "application/json, text/plain, */*",
"Content-Type": "application/json",
"Authorization": "Bearer SHOULDIREMOVETHISFORPRIVACY?WELLJUSTINCASE123456789",
"X-Disable-Provenance": "true",
"User-Agent": "axios/1.7.5",
"Content-Length": "2",
"Accept-Encoding": "gzip, compress, deflate, br"
"baseURL": "http://localhost:3000/api/v1/provisioning",
"method": "put",
"url": "/folder/advmtfqabm3uof/rule-groups/10s",
"data": "{}"
"code": "ERR_BAD_REQUEST",
"status": 400
"config": {
"transitional": {
"adapter": [
"xhr",
"http",
"fetch"
null
null
"timeout": 0,
"env": {},
"headers": {
"method": "put",
"url": "/folder/advmtfqu0ta0wa/rule-groups/10s",
"data": "{}"
"status": 400
weird because performing a GET from postman to api/v1/provisioning/alert-rules/:uid returns:
"id": 33,
"uid": "c93da1ee525c46",
"orgID": 1,
"folderUID": "advmtfqabm3uof",
"ruleGroup": "10s",
"title": "EDITEDFORPRIVACY",
"condition": "C",
"updated": "2024-08-28T15:39:47-06:00",
"noDataState": "NoData",
"execErrState": "Error",
"for": "5m",
"annotations": {
"__dashboardUid__": "educfr0nomjggb",
"__panelId__": "2"
"provenance": "file",
"isPaused": false,
"notification_settings": {
"receiver": "EDITEDFORPRIVACY"
"record": null,
"data": //removed to reduce space in post
For the deleting FOLDER and RULE GROUP case:
PS C:\projects\alerts.replaced.for.privacy.com> node .\removeProvisionedFromFolderGroup.js
"message": "Request failed with status code 500",
"stack": "AxiosError: Request failed with status code 500\n at settle (file:///C:/projects/alerts.replaced.for.privacy.com/node_modules/axios/lib/core/settle.js:19:12)\n
ess/task_queues:95:5)\n at async deleteRuleGroup (file:///C:/projects/alerts.replaced.for.privacy.com/removeProvisionedFromFolderGroup.js:49:24)",
"config": {
"transitional": {
"adapter": [
"xhr",
"http",
"fetch"
null
null
"timeout": 0,
"env": {},
"headers": {
"method": "delete",
"code": "ERR_BAD_RESPONSE",
"status": 500
"config": {
"transitional": {
"adapter": [
"xhr",
"http",
"fetch"
null
null
"timeout": 0,
"env": {},
"headers": {
"method": "delete",
"status": 500
For the one by one case:
"stack": "AxiosError: Request failed with status code 500\n at settle (file:///C:/projects/alerts.grupocayala.com/node_modules/axios/lib/core/settle.js:19:12)\n
at IncomingMessage.handleStreamEnd (file:///C:/projects/alerts.grupocayala.com/node_modules/axios/lib/adapters/http.js:599:11)\n at IncomingMessage.emit (node:e
at Axios.request (file:///C:/projects/alerts.grupocayala.com/node_modules/axios/lib/core/Axios.js:45:41)\n at process.processTicksAndRejections (node:internal/proc
ess/task_queues:95:5)\n at async deleteAllRulesInFolderAndRuleGroup (file:///C:/projects/alerts.grupocayala.com/removeProvisionedFromFolderGroup.js:96:23)",
"config": {
"transitional": {
"adapter": [
"xhr",
"http",
"fetch"
null
null
"timeout": 0,
"env": {},
"headers": {
"method": "delete",
"url": "/alert-rules/a3a69e41bdbe44"
"status": 500
"config": {
"transitional": {
"adapter": [
"xhr",
"http",
"fetch"
null
null
"timeout": 0,
"env": {},
"headers": {
"method": "delete",
"url": "/alert-rules/de8184bfd25246"
"status": 500
File Provisioned Alerts to be deleted or at least removed that “Provisioned” tag to be able to modify it manually
