I am sending all my promtail instances to one loki instance. So I wanted to change the job names from my promtail and send it again to loki. But also I deleted manually all the chunks from loki. And know in grafana I have the old job names and the new ones, but I have an error in log volume.
Is there a way to fix this and also to have my new job names in grafana and delete the old ones?
Also here is my loki-config.yml.
(default configuration)
auth_enabled: false
server:
http_listen_port: 3100
ingester:
lifecycler:
address: 127.0.0.1
ring:
kvstore:
store: inmemory
replication_factor: 1
final_sleep: 0s
chunk_idle_period: 1h # Any chunk not receiving new logs in this time will be flushed
max_chunk_age: 1h # All chunks will be flushed when they hit this age, default is 1h
chunk_target_size: 1048576 # Loki will attempt to build chunks up to 1.5MB, flushing first if chunk_idle_period or max_chunk_age is reached first
chunk_retain_period: 30s # Must be greater than index read cache TTL if using an index cache (Default index read cache TTL is 5m)
max_transfer_retries: 0 # Chunk transfers disabled
wal:
dir: /loki/wal
compactor:
working_directory: /loki/boltdb-shipper-compactor
shared_store: filesystem
compaction_interval: 5m
retention_enabled: true
retention_delete_delay: 2h
retention_delete_worker_count: 150
schema_config:
configs:
store: boltdb-shipper
object_store: filesystem
schema: v11
index:
prefix: index_
period: 24h
storage_config:
boltdb:
directory: /loki/index
boltdb_shipper:
active_index_directory: /loki/boltdb-shipper-active
cache_location: /loki/boltdb-shipper-cache
cache_ttl: 24h # Can be increased for faster performance over longer query periods, uses more disk space
filesystem:
directory: /loki/chunks
limits_config:
retention_period: 182d
per_stream_rate_limit: 512M
per_stream_rate_limit_burst: 1024M
reject_old_samples: true
ingestion_burst_size_mb: 16
ingestion_rate_mb: 16
chunk_store_config:
max_look_back_period: 744h
#table_manager:
retention_deletes_enabled: false
retention_period: 172h
ruler:
storage:
type: local
local:
directory: /loki/rules
rule_path: /loki/rules-temp
alertmanager_url: localhost
ring:
kvstore:
store: inmemory
enable_api: true
