New to Loki so I am sorry if it is a dumb question.
I am getting an error when trying to update to Loki 3.0.0(from Loki 2.9) about needing to set compactor.delete_request_store which I am guessing from the examples it can(needs?) be the same as my object_store for single store installs(S3 in my case). Is this correct? If yes, why isn’t this the default value and it needs to be set by hand? In 2.9 retention(deletion) works fine I see without this parameter.
I believe it gives you the option to have it set different from object storage. If you are using S3 for Loki I’d just set it to S3.
Thank you for the advice! This is what I will do. I just think this could be the default value(whatever is set in object_store) and if you want to change it, you can configure it.
Hi @aradu, Good Day
Is the compactor working fine for you to delete the chunks in loki in windows with the loki & promtail 2.7.2
If yes please suggest me how to define config file for compactor in loki or please share here the config file.
Thanks in advance
Jaibharath reddy
bharathreddy028@gmail.com
