Compactor is not working
My config Loki:
Loki v.3.4.2
Grafana v.11..
schema_config:
  configs:
      store: boltdb-shipper
      object_store: filesystem
      schema: v13
      index:
        prefix: index_loki_blob
        period: 24h
storage_config:
  boltdb_shipper:
    active_index_directory: /data/loki/boltdb-shipper-active
    cache_location: /data/loki/boltdb-cache
    cache_ttl: 24h
  filesystem:
    directory: /data/loki/chunks
compactor:
  compaction_interval: 1h
  delete_request_cancel_period: 12h
  delete_request_store: filesystem
  retention_delete_delay: 2h
  retention_delete_worker_count: 10
  retention_enabled: true
  working_directory: /data/loki/compactor
limits_config:
  allow_structured_metadata: false
  ingestion_burst_size_mb: 200
  ingestion_rate_mb: 20
  ingestion_rate_strategy: local
  max_chunks_per_query: 200000
  max_entries_limit_per_query: 1000
  max_global_streams_per_user: 524288000
  max_query_lookback: 14d
  max_query_parallelism: 8
  max_query_series: 100000
  max_streams_per_user: 100000
  per_stream_rate_limit: "512MB"
  per_stream_rate_limit_burst: "1024MB"
  reject_old_samples: true
  reject_old_samples_max_age: 336h
  retention_period: 336h
  split_queries_by_interval: 15m
querier:
  engine:
    max_look_back_period: 336h
  max_concurrent: 20
  query_ingesters_within: 2h
table_manager:
  retention_deletes_enabled: true
compactor does not work, after 14 days, the old data is not deleted and the disk fills up until it runs out. What to do? What should I do?
Try disabling table_manager. If that still doesn’t work, see if you can find any error log from compactor.
The table_manager retention settings do not apply when you’re using boltdb-shipper.
boltdb-shipper retention relies only on the compactor, not table_manager.
You can try
schema_config:
  configs:
      schema: v13
      index:
        period: 24h
      **retention_period: 336h**  # <- You should move/add this here
The retention_period under limits_config is global, but schema_config.configs.retention_period is what the compactor uses.
Try check the log for loki, and look for something like
"“retention applied to table index_20240610, marked for deletion”.
when adding retention_period: 336h to schema_configure, I have an error:
failed parsing config: /etc/loki/loki-local-config.yaml: yaml: unmarshal errors:
line 55: field retention_period not found in type struct { PathPrefix string “yaml:“path_prefix””; Prefix string “yaml:“prefix””; Period model.Duration “yaml:“period””; Tags config.Tags “yaml:“tags”” }. Use -config.expand-env=true flag if you want to expand environment variables in your config file
i have this loki config on k8s render from helm loki chart 6.46.0
auth_enabled: false
bloom_build:
builder:
planner_address: loki-backend-headless.platform-logging.svc.cluster.local:9095
enabled: false
bloom_gateway:
client:
addresses: dnssrvnoa+_grpc._tcp.loki-backend-headless.platform-logging.svc.cluster.local
enabled: false
chunk_store_config:
chunk_cache_config:
background:
writeback_buffer: 500000
writeback_goroutines: 1
writeback_size_limit: 500MB
default_validity: 0s
memcached:
batch_size: 4
parallelism: 5
memcached_client:
addresses: dnssrvnoa+_memcached-client._tcp.loki-chunks-cache.platform-logging.svc.cluster.local
consistent_hash: true
max_idle_conns: 72
timeout: 2000ms
common:
compactor_grpc_address: ‘loki-backend.platform-logging.svc.cluster.local:9095’
path_prefix: /var/loki
replication_factor: 3
storage:
s3:
access_key_id: nqTUcUxxxxxx
bucketnames: loki-logging
endpoint: http://uat-minio-logging.com.vn:9000
http_config:
idle_conn_timeout: 90s
insecure_skip_verify: false
response_header_timeout: 0s
insecure: false
s3forcepathstyle: true
secret_access_key: 1Wr8lhGYK8sJN362ZFg
compactor:
compaction_interval: 5m
retention_delete_delay: 10m
working_directory: /tmp/loki/compactor
frontend:
scheduler_address: “”
tail_proxy_url: “”
frontend_worker:
index_gateway:
mode: simple
limits_config:
allow_structured_metadata: true
max_cache_freshness_per_query: 10m
query_timeout: 300s
retention_period: 360h
volume_enabled: true
memberlist:
join_members:
  • loki-memberlist.platform-logging.svc.cluster.local
pattern_ingester:
enabled: false
query_range:
align_queries_with_step: true
cache_results: true
results_cache:
cache:
background:
default_validity: 12h
memcached_client:
addresses: dnssrvnoa+_memcached-client._tcp.loki-results-cache.platform-logging.svc.cluster.local
timeout: 500ms
update_interval: 1m
ruler:
storage:
s3:
access_key_id: nqTUcUGSxxxxx
http_config:
insecure: false
secret_access_key: 1Wr8lxxxxxYK8sJN362ZFg
type: s3
wal:
dir: /var/loki/ruler-wal
runtime_config:
file: /etc/loki/runtime-config/runtime-config.yaml
schema_config:
configs:
index:
period: 24h
prefix: index_
object_store: s3
schema: v13
store: tsdb
server:
grpc_listen_port: 9095
http_listen_port: 3100
http_server_read_timeout: 600s
http_server_write_timeout: 600s
storage_config:
bloom_shipper:
working_directory: /var/loki/data/bloomshipper
boltdb_shipper:
index_gateway_client:
server_address: dns+loki-backend-headless.platform-logging.svc.cluster.local:9095
hedging:
at: 250ms
max_per_second: 20
up_to: 3
tsdb_shipper:
use_thanos_objstore: false
tracing:
enabled: false
but retention not working too, can you check for me. Thank you!
