Sorry for my bad English, my native tongue is Dutch
I am having a free account on grafana.com -
I am trying to match metrics, traces and logs for a service using the Observability\Application\services -
I have a .net 8.0 service running in a container
the setup for otel is like this example
opentelemetry-dotnet/examples/AspNetCore/Program.cs at main · open-telemetry/opentelemetry-dotnet · GitHub
and I am setting some environment variables in de docker compose file
environment:
OTEL_RESOURCE_ATTRIBUTES: service.namespace=${ApplicationSuite},ApplicationSuite=${ApplicationSuite},facility=Abiware.DGH.Prenotifications,deployment.environment=${ApplicationSuite}
And I am using an Alloy container to send this telemetry to grafana
What happened?
I am receiving the 3 types of telemetry but when I go to observabiltiy/application the logs are not matched with my service -
My logs are match with my service.
But who is responsible for generating the labels that I seems to miss (assuming that is my problem) -
In the service I see this as a query (explanation of the query show me that exporter and job are labels)
{exporter="OTLP", job="Development/Abiware.DGH.Prenotifications.Api"} | json | resources_deployment_environment=~"Development" | line_format `e[1m{{if .level }}{{alignRight 5 .level}}{{else if .severity}}{{alignRight 5 .severity}}{{end}}e[0m e[90m[{{alignRight 10 .resources_service_instance_id}}{{if .attributes_thread_name}}/{{alignRight 20 .attributes_thread_name}}{{else if eq "java" .resources_telemetry_sdk_language }} {{end}}]e[0m e[36m{{if .instrumentation_scope_name }}{{alignRight 40 .instrumentation_scope_name}}{{end}}e[0m {{.body}} {{if .traceid}} e[37me[3m[traceid={{.traceid}}]{{end}}`
Going into menu Drilldown/logs/labels is showing me that I have the labels detected_level, service_instance_id, service_name, service_namespace, deployment_environment
No -
