Default Grafana dashboard not changeable
    Grafana Version 8.5.15 as a Docker Installation on Synology NAS (Linux)
    I am trying to set a specific dashboard as default (when opening Grafana)
    I already achieved it by setting the desired to favourite (Set Star) and select it within the preferences as Default Dashboard
  • What happened?
    It worked - for the firrst time, after that I cannot change it anymore (setting/removing stars, removing it from Preferences/Default Dashboard, etc.) - it stays the dashboard I setup in the beginning and not taking any change I try to achieve
    The default dashboard should be changed accordingly when selecting another dashboard that is set as “starred”
    Not sure what I should give as input here
    No errors - not in UI nor in log-files
    No - tried to google but could not find any useful hints, that’s why I
Hi @mtropper74,
Thanks for opening this issue.
Based on your steps of reproduction, I was not able to reproduce it on my test machine. I tried it on version 9.3.2 and seems to be working correctly.
Can you please try to reproduce this same issue on the current stable version of Grafana and then let us know your feedback?
Thanks
Hi @usman.ahmad,
thanks for your reply - I updated Grafana to the latest version (which for Teslamate still is a 8x Version, not 9x) and then I found that changing the preferences for the User (not Organization) is also helpful - now it works! So just in case someone is struggling like myself was - there are two different preferences regarding the default, one on the upper left navigation panel and one on the bottom part, both change that value but only the lower one did the trick for me!
Thanks again
All the best
