Default datasource on a per-dashboard basis?
Is there any way to set the default datasource for a dashboard to be a template variable? I already have a datasource template variable, but it’s tedious to set each graph to use that variable.
Unrelatedly: Is there a way to set the default time zone for a whole Grafana instance to be UTC? I work with a distributed team, and we never want any of our graphs to display in browser local time because it makes discussion more confusing.
  1. You can sadly not specify a data source template variable to be the default data source
  2. You can change default timezone to be UTC in profile or organization preferences.
