9.2.3 -
Using a database with timestamps having time in local timezone UTC+1. When selecting “last 6 hours” then the first hour does not contain data. -
Simply by selecting the time column which includes the local timestamps. the query also has a filter on “WHERE $__timeFilter(time)” in order to speed things up, the db has 2 mio records. -
What happened?
first hour missing in the display of the graphs -
no -
no.
Have created a work arround that, using
WHERE time BETWEEN DATE_SUB(FROM_UNIXTIME(${__from:date:seconds}), INTERVAL 1 HOUR) AND DATE_SUB(FROM_UNIXTIME(${__to:date:seconds}), INTERVAL 1 HOUR)
as filter in the query. But that looks complicated, was hoping to fix the issue with some timezone settings in grafana, but did not find the correct setting.
I see that iobroker-db seems to store timestamp in UTC0, that seems to work fine. Unfortunately the db in this case has timestamp stored as local time which is UTC+1
Any better idea as the workarround i found?
