Db query error: pq: relation "<table>" does not exist
    Grafana v11.2.1 (6291d0d714)
    Using postgres as a data source run multiple queries to eventually join into a single table
    Using a table visualization.
    I add two queries A and B
    Both A and B are valid on their own (verified using explore)
    When both A and B are enabled within the visualization config I get the error db query error: pq: relation "<table>" does not exist
    If I add query C then A and B will now return the above error
  • What happened?
    Valid query results in the error db query error: pq: relation "<table>" does not exist
    My valid queries would execute successfully and I could use a join transformation to combine output from the multiple queries.
    No, but any two valid postgres queries should reproduce this issue
    The UI displays db query error: pq: relation "<table>" does not exist for each query that’s not the last one executed
    No
