What Grafana version and what operating system are you using? Raspberry pi / Grafana v12.3.1 (0d1a5b4420)
What are you trying to achieve? retrieve the max of values stored in postgresDB for the current month starting 01.01.2026
How are you trying to achieve it? Using date_trunc(‘month‘,ts)
What happened? The trunc command returns a date in the previous year for timestamps 2026-01-01 00:30:00 even though the postgress database is using a table where the ts is defined as timestamptz
What did you expect to happen? The same result as returned in DBeaver (which is giving back the date_trunc(‘month’, 2026-01-01 00:30:00 ) being 2026-01-01 00:00
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. N0
