Date group by not working as expected when date range is from 1-nov the group by feature working correctly but when the date range set to after 1 nov date group by not working see the screenshots below
Grafana version: 9.3.1
Data Source: infinity
Hi @usamaaltaf420,
I think I understand this case from a previous post where the Transformation were not working. As an alternative, you can use Grafana’s Override function to achieve this.
I had replied to a post where I attached a .gif file which contains the steps as how to do it (in your case you may need some more modification with the “group_by” but I think should be possible).
Let us know if this helps. ![]()
Hey thanks you for your help but the thing is I know about the Override function of Grafana and I’ve tried it already with group by but got no success.
I don’t know if I am doing it right or wrong please let me know I am attaching the screenshot please see this
@usmanahmad @yosiasz can you help me with this issue?
Please post sample of your data and the result you expect tobsee from the sample data?
So @yosiasz when my data is like below, the date group by feature is working when date is from 1 nov
"value": [
"startDateTime": "2022-11-01T11:03:11.811Z",
"inviteDateTime": "2022-11-01T11:03:06.68Z",
"failureDateTime": null,
"endDateTime": "2022-11-01T11:03:15.811Z",
"duration": 4,
"callType": "ByotOut",
"successfulCall": true,
"finalSipCode": 0,
"callEndSubReason": 560000
"startDateTime": null,
"inviteDateTime": "2022-11-01T11:03:07.514Z",
"failureDateTime": "2022-11-01T11:03:07.514Z",
"endDateTime": null,
"duration": 0,
"callType": "ByotIn",
"successfulCall": false,
"finalSipCode": 404,
"callEndSubReason": 511404
And when data is like this starting from 2 nov it is not grouping.
I know this can be a issue of date format but don’t know how to do it
"value": [
"inviteDateTime": "2022-11-02T03:52:57.994Z",
"failureDateTime": "2022-11-02T03:53:06.652Z",
"duration": 0,
"finalSipCode": 487,
"callEndSubReason": 540487
"inviteDateTime": "2022-11-02T03:53:07.503Z",
"failureDateTime": "2022-11-02T03:53:16.776Z",
"duration": 0,
I want to group inviteDateTime
Show us a screen shot of the transformation you are using with 11-02 and show us what is “not working”. Is it the total or the count? And what should the correct/working result?
Thank you so much you saved my whole day
one little help please if you don’t mind I want to see successfulCall like how many true that day and how many false can I use this with your code
parse-json
| jsonata "value[successfulCall=true]"
| summarize count() by "inviteDateTime" , "successfulCall"
value[successfulCall=true] and false wants to see both ![]()
tried like this but not working
parse-json
| jsonata "( $.value{ inviteDateTime: { 'inviteDateTime': $substring(inviteDateTime, 0, 10) } } ~> $each(function($v){$v}) )"
Sorry
but I mean that I want to see how many calls are successful and unsuccessful each day
like on 2022-11-01 total calls: 90, successfulCalls: 40, unsuccessfulCalls 50,
I tried to modify your code like this
parse-json
| jsonata "( $.value{ inviteDateTime: { 'inviteDateTime': $substring(inviteDateTime, 0, 10) }, successfulCall: true } ~> $each(function($v){$v}) )"
| summarize count() by "inviteDateTime", "successfulCall"
but no success hoping I will get it ![]()
I also tried this
parse-json
| jsonata "( $.value{ inviteDateTime: { 'inviteDateTime': $substring(inviteDateTime, 0, 10) } } ~> $each(function($v){$v & {'successfulCall': false} })) | ( $.value{ inviteDateTime: { 'inviteDateTime': $substring(inviteDateTime, 0, 10) } } ~> $each(function($v){$v & {'successfulCall': true} }))"
yes I tried I am a noob on jsonata but don’t worry I’ll get it.
by the way thanks for your help ![]()
