Date format changing to epoch time format when assigned as a variable
When assigning a variable name to date column in a MSSQL table the date format is changing from “yyyy/mm/dd” to an epoch format. I need to keep it in a “yyyy/mm/dd” format to allow end users to select a specific date from the pull-down list.
    8.1.1
    Create a pull down list of report dates that an end user can select to show the respective graph for that date
    Assign a variable name to the date column in a MSSQL table. The date format is yyyy/mm/dd in the table.
    Variable query: select distinct(Report_Date) from visual
  • What happened?
    The preview/results shows up as an epoch time
    Example: 1628640000000
    Date format being “yyyy/mm/dd”
    no
    None instructions
you want to create a new date dropdown?
why not use the existing one?
The dates in the db are static dates relating to unique static data sets that occurred on the selected date. The data viewed is all static and there is no relationship to the time picker other than changing the graph resolution. The end user would select a date to view the specific static data (note: it works as it should in V6, the only difference the DB is Influx instead MSSQL)
Solution: select distinct convert(varchar, Report_Date) from visual
