I have seen others complain about this with no good solution (re-structuring my database is not an option.)
So, heres how I get date to show correctly in a table, simply convert timezone to utc on the go
your select command needs to be something like
SELECT
column1,
column2,
CONVERT_TZ(`column_name_with_date`, '-05:00', '+00:00') AS `date`
FROM
`db`.`table`;
just change -05:00 to match your time offset
Hope this helps ![]()
