I think it’s better if there any filter in the datasource level, such as for multi tenancy support.
So, from the datasource level, already filtering the documents result and this is can reduce the process to filter inside the dashboards and panels
I think this is not in the templating like in the
filtering-option-for-elasticsearch-datasource
It’s merely filtering first before use templating for multi-tenancy purpose
If there no filter, just use the normal datasource…
Regards,
Fadjar Tandabawana
