Datasource variable
    Grafana v10.2.2
    I want to use the datasource variable in a link
  1. I am defining a variable called ds in settings → variables which is for prometheus data sources
  2. I am defining a link in settings → link and using the variable ds defined for datasource above
  • What happened?
    Now I have upgraded to v10.2.2 the ds variable is the dsUID and not the dsName so my links no longer work as expected.
the confusing thing is that the ${ds} variable is ok if used in a panel title but nok if used in same panel content.
    The variable list as strings name for my defined data sources and I expected the variable to be the same i.e. the ds as a string and not the dsUID .
    “to”: “now”
    “timepicker”: {},
    “timezone”: “”,
    “title”: “ds example”,
    “uid”: “ef9f697a-cd05-4668-8dec-5093b04e6f3a”,
    “version”: 3,
    “weekStart”: “”
  • Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly
    No errors
    None specific
Try:
${ds:text} - it should return datasource name
${ds:raw} - it should return datasource uid
Grafana uses name or uid automatically, based on the context. I guess you can override that magic with advance variable formatting.
Thanks - works
