MariaDB Query (simplified, format table):
SELECT
n.created_at AS "time",
o.id AS "product",
n.data AS "data"
FROM
db.o
LEFT JOIN db.n ON o.id = n.parent_id
ORDER BY
time;
Grafana table of pure query:
Transformations:
Transformation 3 is extra. It helps to work around the upcoming problem a little bit. Just forget it.
Transformation 5 is needed to apparently restore the field type.
The result as graph:
The issue becomes clear in the table:
New ‘time rows’ do not contain the current status of unchanged products and thus become NULL and empty in the graph, NULL is their new state.
It’s almost like Transformation 4 option “empty value” should have the option “Last non-NULL”.
How to solve this by either a different approach or fine tuning?
Edit: Setting T4 “Empty value” to “Null” and in graph “Connect null values” to “Always” helps to eliminated NULL in between values, but not to prevent NULL after the last value.
