Hey everyone.
We are working on a distributed tracing POC. Our decision to go with Grafana will primarily rely on the possibility of one specific use case. I have attached a visual of an example trace. What we want to calculate is the difference in duration between two spans of the same trace. “SUB” in the visual signifies a subtraction operation.
The scenario for an API call is: We want to calculate the latency that we add to an API call. This means subtracting the time taken by an external client. We want the results as a time-series and create alerts on it. (This basically means that if “OUR” latency crosses a certain threshold, we’ll act on it. Spike in external client latency does not matter.)
Any help on this will be great. Thank you!
EDIT:
I tried doing the following in the Grafana sandbox. Making two queries and then trying to subtract them in the Transform tab. Doesn’t work.
