Grafana dashboard couldn’t be saved after I included TEXT panel containing HTML, CSS and JS code in it. I was trying to use a script to autoscrol an HTML table in Grafana dashboard. The TEXT panel shows correct output, but the ‘Save’ button doesn’t work and the dashboard changes cannot be saved.
On saving my TEXT panel that contains a combination of HTML, CSS and JS code, the ‘Save’
button on the dashboard should save the the newly made changes.
Reproducing the issue:
Create a dashboard. From visualization, select ‘TEXT’ panel. Change to ‘HTML’ mode. Paste an auto scrolling code containing HTML, CSS and JS code.
Environment:
Grafana version: v6.6.2
OS Grafana is installed on: Windows
Grafana plugins: TEXT panel
